02GF74
ok clever peeps, need to find adaptor to fit shimano calipers to this.
replacing XT 4 pot by DX(?) 2 pot.
adaptor needed as XT have axial holes whereas DX have radial i.e. holes are 90 degrees out.
discs are 160 mm dia.,
hole distance in mount is 51 mm ish
caliper bolt distance is 74 mm
rear XT caliper is different to front in that the lugs are different.
(you can see the front XT in the first photo and notice the lugs are different to the rear)
so what do I need to get?
