Have you actually tried the cantis yet? Either way they use the same mounts. Lever pull will not really make much difference, IMO.
It will, unless the v-brakes are
mini vs,
@Andy2 .
Brake Levers for Direct-pull Cantilevers (i.e. V Brakes)
Direct-pull cantilevers have double the
mechanical advantage compared with traditional brakes, so they require special brake levers. Direct-pull brake levers pull the cable twice as far, half as hard. The lower mechanical advantage of the lever compensates for the higher mechanical advantage. of the cantilever. It is not generally safe to mix and match levers/cables between direct-pull and other types for this reason.
- Conventional brake levers used with direct-pull cantilevers will usually not pull enough cable to stop in wet conditions without bottoming out against the handlebars. In dry conditions, they either won't work, or will grab too suddenly.
- Direct-pull brake levers used with any other type of brakes will feel nice and solid when you squeeze them, but due to their lower mechanical advantage you'll need to squeeze twice as hard to stop as you should, so unless you are a lightweight rider with gorilla-like paws, this combination isn't safe either.
Drop-bar Levers
To make a brake lever with low enough mechanical advantage for direct-pull cantilevers, the cable must run twice as far from the lever's pivot point. This is easy enough to do with levers for straight/upright handlebars. Levers for drop handlebars are harder to configure for direct-pull brakes, and currently, there are only a couple of drop-bar levers made that are compatible, the
Dia Compe 287V and the Cane Creek SCR-5V "Æro" levers.
Most newer drop bar bikes are have Ergo or STI brake/shifter units as original equipment. Direct-pull cantis are not compatible with these. Other types of shifters may of course be used, along with the special brake levers. In any case many cyclists prefer bar-end shifters. These are simpler and less expensive than brake-lever shifters, and give an indication of what sprocket is in use: brake-lever shifters return to the same position after every shift."
http://www.sheldonbrown.com/canti-direct.html
