New Horizon
PayPal or bank transfer please, postage extra at cost, most will be £1-£3 each for second class, will combine for multiples, or collect from Hereford.
NEW SRAM eTap HRD (hydraulic) post mount disc calliper with mounting bolts (no rotor or pads), 1255 miles, as new, £60
NEW Shimano XT Icetec 140mm centrelock disc rotor, no centrelock, 890 miles only, £14
TRP Spyre 6 bolt rotors with 6 bolts, 160mm and 140mm, new, £8 each
Brake cable stem hangers - black alloy, unbranded, both new, both 1 1/8" int dia, 15mm drop, with cable adjuster and 35mm drop with cable adjuster, £6 each
Rear brake cable hanger - fits to seat post bolt. £1
M-Part seat stem clamp - black alloy, new, 34.9mm int dia with lip to sit on top of tube, £4
Star nut, bolt, cap - the nut measures 26.5mm, £2
Shimano M510 (Deore) 32T chainring, new, £8
Velo Orange Milan Handlebars. Width is about 570mm; reach is 110mm; there is around 25mm of rise; the grips sweep back about 35-degrees; the bulge is 25.4mm; and the grip area is about 170mm long. Polished aluminum alloy. Milan bars work with regular MTB (22.2mm) grips, brakes, shifters, etc, but not inverse levers or bar-ends. New, £18 (or £20 with the grips below)
Velo Orange bar grips - brown basket weave, fit 22.2mm bars easily and 23.8mm bars with a little effort, new, £4
Nylon toe grips with reflectors and straps, new, £5
Cantilever stud caps - fit on unused studs, £1 or free with anything else
Zefal tyre pressure gauge, Schraeder only, £2
Shimano derailleur bash guard, 80’s vintage, £3
CatEye Strada Slim wireless computer with 3 head mountings and 2 sets of fork sender units and magnets, allowing you to easily swap the head unit between bikes. All in excellent condition, no marks or scratches on the screen, batteries included in the head and one sender (no guarantee on their life). £28
SOLDTRP Spyre SLC Disc Brake - boxed, new, post mount / Front or Rear / with TRP pads and mounting bolts.
The SLC is the nicer version of the standard SL - it has a top cover, a nice dark grey finish, neater cable fixing and a carbon arm.
Includes L2 (140R/160F) IS to PM adapter and L3 (160R/180F) IS to PM adapter. £45
SOLD flat mount to 160mm post mount adaptor, £6
SOLD flat mount to 140mm post mount adaptor, £6
SOLD Park Tools chain checker - CC-3 (1.0 and 0.75) excellent condition, £5
SOLDLezyne bottle cage pump brackets, pair, new, £1 each or free with anything else
SOLDHeadset spacer with threaded lug for a bell fixing, 1 1/8” with spacer for 1", new, £4
SOLDAbus TexKF lock holder, uses Klickfix mount which can be used for other things, new, £3
SOLDBikers Dream portable foot pump - very popular at one time and quite effective. Boxed with nylon frame carry bag and accessories. £5
SOLD
SOLD
SOLD
SOLD
SOLD
