^^^^^^^how do you adjust the brake lever. I want to move it in a couple cm's. Can't see any screw or nut!! The ones in the photos are just studs?? Thanks for yr help!!
There is a screw inside the lever if you go with an allan key from the front between lever and cable adjustment screw. I hope that this is understandable - sounds a bit weird.
