Broken tilt and turn window -advice please
Levo-Lon
Can you get at the handle screws Paul ?
Is it a plastic upvc job..
if its a plastic window one screw will be under a plastic cap..the other is under the handle.
remove the screw with the cap the other under the handle so u can remove it and then see if it will turn using the window mechanism
gbb
Peterborough
Stuck gasket..that happens to mine once In a while. I usually bang the frame with a clenched hand, it usually pops it.
U
User33236
[QUOTE 3650043, member: 45"]We have tilt and turn windows. One of them is stuck in the closed position, with the handle turning freely.
Does anyone know how I can get it open to fix it?[/QUOTE]
Get one of you locals ne'er do wells / criminal element to have a look. They will have it open in seconds.
Levo-Lon
Probable best to call a window dr man Paul as they will know how..
anyone like this in your area? Or a window fitter may help
think its repairable but a new window may be cheapest option
http://www.windowrepairslincs.com/
[QUOTE 3650725, member: 45"]Thanks. I've just remembered what it was I liked about you.[/QUOTE]
Get it in the corner or it'll bounce back and kill you.
classic33
Tried the metal strip idea. Assuming you can open one half of the window & insert the strip. You have then the problem of trying to get it past the rest of the locking mechanism. The closer to the "locked" section the harder it becomes.
