bence8810
Member
- Tokyo, Japan
Hi all,
I am brand new to Brompton's and brand new to this forum - 1st post here, sorry if I may sound silly.
I've been riding a Dahon Metro 2010 for about 3 years now, the reason why I bought it was so I could bring it with me to the small islands just south of Tokyo where I frequently go fishing / camping. The Dahon served me right but I always had my eye on a Brompton, not sure if it was the hype or the small fold that I wanted it but I am glad I got it.
p.s. I am also a film shooter and went through a few cameras before dropping the extra $$$ on a Leica and never looked back - I expect the same will happen to the Brompton.
So - the 2 questions I have - again if I overlooked something please bear with me. I watched videos and read threads / manual etc, still unsure what to do.
First of all the seatpost clamp, the QR thing. It is plastic and looks surprisingly cheap for the amount of $$$ (or Japanese yen rather) I dropped on this bike. I am having a hard time finding the balance between the clamp not tightening down the sleeve strong enough so the seat post goes in gradually over bumps and over-tightening the nut so that even with the clamp open, the seatpost won't slide in for folding.
I noticed that the plastic clamp sort of rotates beyond the central nut, I assume the plastic isn't strong enough and when the nut is tight, it starts slipping / over-turning. Picture below.
What do you guys do to sort this out? I read that adding an extra QR on the post will work but isn't the charm of the brompton simplicity and things just working out of the box? I read people sanding down the seat post etc, really not something I'd like to do as long as there is a better way like adding on a stronger lever / clamp that won't slip etc.
Second is the bumper / damper in the back between the main body and the rear triangle. I got the firm block and I am happy with the way it rides, I am 190cm and 82kg so it is under a heavy load but still feels firm and sporty, not at all wobbly. What I don't like / don't understand is the little play between the frame and the rear triangle even when in the locked position. If I lift the bike by the seat, there's a little play and the body moves first - a small gap is formed between the frame and the damper and then the back moves as well. It is perhaps only 5mm but still annoying, if i forget about it and just want to move the bike a little, it makes this clicking sound. I took two photos, first with the bike firm on the flat and the second with me lifting it, you can see there the gap. Is this normal?
Flat on the ground:
Lifted and showing gap:
Thanks a lot,
Ben
Flat on the ground:
Thanks a lot,
Ben
