stuarttunstall
- Yorkshire Wolds
Hi
I have a silly question if anyone can help..
I have just been out to check the bike over ready for a little ride Sunday, I have not used it for about 3 weeks due to the weather … I keep the chain well lubed with dry lube as I use it in the dry.. Now looking at it looks like the chain is covered in a rust/brown coloured substance which seems to wipe off easy enough..
I have just washed off the chain with a jet of water and bike cleaner and it looks to come up really clean with no signs of rust so I have re-lubed and lubricated the cassette .. The cassette does have a couple of tiny rust marks on a couple of the gears but nothing really..
Do you know what this could be? Is it rust in the chain or just damp/muck mixed with the lube? never had this appear before, just the last month I would say..
I am taking it the LBS next Friday to get it serviced to keep the 5 year warranty up to date so will ask them to check the chain/cassette and have them changed if needed, I suspect not as it has only covered about 1000 miles since June 2018 ..
STuart
STuart
