Btwin Co2
Bollo
Failed Tech Bro
Winch
I've got one at the moment and they work as well as the branded ones. The only genuinely bad CO2 inflator I had was the wiggle Lifeline own brand jobbie. Just awful.
Just make sure you don't use it with uncovered hands (or wet gloves :sad:) or you'll likely end up with cold burns.
Supersuperleeds
Leicester
I use a piece of foam lagging for mine that the canister sits in
Deleted member 23692
I slip a short section if 23mm inner tube over my (16g) cartridges, and I still have skin on my fingers :smile:
alecstilleyedye
nothing in moderation
i've got one from aldi from a couple of years ago.
only used once (as a test of concept prior to considering relying on it and a mini-pump), and it worked really well. it was supplied with a bit of foam rubber to avoid the cold burns as described above.
it has a valve tap, so it makes it easier to use and less easy to mess up…
