Cadence sensor help?
Milzy
My Prime deal arrived. My cadence sensor won’t fit on the non drive side - inside. Why can’t it fit on the drive side where it’s clear?
I then fit to my left shoe. This led to sparadic intimitant readings. A lot of the time just reading 0.
Any solutions?
OMG Edit, it should clear if I don’t use its pod! *slaps face*
Milkfloat
An Peanut
Midlands
Which one the Wahoo RPM, if so it should easily fit on the inside of the left crank, either with zip ties or sticky tape.
Milzy
Milzy
If I remove it from the pod then it might. There’s little gap on my TCR.
