It's going to be a more aggressive ride as the Addict is a race bike. Is that what you want or are you simply looking for a carbon bike to upgrade but match the Trek? If so compare across the Trek range perhaps as a start?
As said, stack and reach are the starting point
This is why trying to find an online bargain without trying the bikes can prove misguided. A bargain may end up losing you money
Evans have the addict 20 in a 54cm. Why not get the Birmingham store to get one in, get a good test ride. It's in your budget, £60 refundable deposit if it's no good
Bearing in mind it would be poor form to then buy elsewhere...
Just been to a shop in Leamington Spa that has a 2014 Addict 56. Felt pretty stretched out, more so than the Trek but standover seemed ok. ALOT more seat post out on my Trek though in comparison so I'm still undecided...
If it felt stretched out and had a 100mm or shorter stem then it's pretty likely you should be looking for a smaller size. They say a stem shorter than 10cm can make a bike feel twitchy at the front end so ideally you don't want to be 'making' the bike shorter by fitting a really short stem.
