Yes.will it function on a normal 10 speed set up
I think it just means the chainrings have 'shifting pins' on them. (instead of just plain rings)Yes.
But it's 10 speed 2008 ESP - someone else (the seller's) typoing (I'm guessing):
ESP (Enhanced Shifting Performance) Actuation System is a system that was specially developed by Campagnolo to improve the shifting synchronism. Thanks to the special design of the gears, now there are two specialised sectors for upshifting, diametrically opposed, and two sectors for downshifting, also diametrically opposed. (Comment: Have no idea what that means!)
Campagnolo site
You've seen the chainset with Ultradrive EPS 'written' on it? Just checking, because iirc Chorus has been 11 speed for longer than EPS has been out.it's definately eps on it though not esp
One of these, from the 2004 catalogue:You've seen the chainset with Ultradrive EPS 'written' on it? Just checking, because iirc Chorus has been 11 speed for longer than EPS has been out.
From a quick read of the tech specs in the catalogues, I think the carbon Chorus 10sp cranksets use a 102mm bottom bracket, whereas the Daytona used a 111mm. So you might need a new BB. These are readily available though.Yes it's all campagnolo
