I have recently brought an old cycle off a friend as i'm starting out tri racing and i didn't want to splash out on a new bike if i don't like triathlon, it has campagnolo gearing with mirage ergo shifters, a veloce rear deraillier and a 9 speed cassette. The issue that i'm having is that when i'm shifting gear the largest 4 gears shift very well but then for about the next 3 cogs the chain clicks as if not located properly. I've had a little tinker with the tension of the cable and this just takes the issue from the original cogs to the previously ok ones, all spacing between cogs is equal so i can't see why the shifting isn't constant, has anybody got any advice as to what could be causing this and remedies if anyone has any.
