Joe24 said:Yes, but if you put them back in again its likely to cause a stiff link.
But, if you wanted to just split a chain then pick any link you like the look of.
Toby_2009 said:thanks, so what do i do if I dont want to create a 'stiff link'?
Joe24 said:Put in a quick link, like the 'Sram powerlink'
http://www.chainreactioncycles.com/Images/Models/Full/871.jpg
Its an outer plate, and you basicly just put this into the chain, and it means you can take the chain off/put it back on as much as you want.
+1 All that it needs is a little wiggle to make sure that it's free.chillyuk said:So how did we manage for generations of cyclists before these quick links were developed? I have joined many chains and never had a stiff link where I have made the join.
02GF74 said:older chains had pin pushed in, you could push the pin and then push it in and all was well.
then as the chains became narrower,8 spd, shimano and other manufacturers swage the pin ends so they wont come out, this means that when the pin is pushed out, it isn't easy to push it back in and you end up damaging the link. for that pupose shimano sell a special pin to join chains, for the extortionate sum of £ 1 (yes, a quid for a single effing pin) . this pin has a pointy end so can go into the link easy peasy like.
