Can you add extra links to a Shimano 12 speed chain.
Punkawallah
While it -can- be done, I’m not sure it -should- be done. Emergency use excepted, of course.
T4tomo
Can this be done or do you end up joining two bits with two quick links?
Yes & Yes
i.e the best way to lengthen a (12 speed*) chain is to join two bits with two quick links
*speed is irrelevant, save for you could pop pins in and out on was is 10 or 9 speed and below, but never sure how reliable a fix that was.
Dadam
SW Leeds
Why? Genuine question, I was musing on this the other day.
Advice from many is to carry a spare quick link to fix a broken chain. Very sage advice. But if you had two quick links together on the chain, if the chain breaks you can just move one to bridge the gap. No chance of forgetting to carry a spare as it's on your chain already
They're both under the same load so no more likely to snap surely.
  • Like
Reactions: C R
