Hi
I'm looking for an endurance road bike, and am considering the Cannondale Synapse. I'm not able to try one out (although I understand that ideally, I would try it), so will be buying online, but am looking for some sizing advice.
https://www.cannondale.com/en-gb/bikes/road/endurance/synapse-carbon/synapse-carbon-womens-105
I'm 159cm tall, with a 76cm inseam. At this height on Cannondale's size chart, I'm at the top end of the height range for the 44cm frame, and the low end of the range for the 48cm.
I was set on getting the 44cm, as the length of the reach is similar to that of other bikes I've been comfy on in the past. However, I then spotted that the seat tube is only 37cm, and it made me wonder if I'd struggle to get the saddle high enough while leaving enough seatpost inside the frame. But with the 48cm, I'm not sure if the reach will be too long. It's only a 6mm difference from the 44, and the stack is higher, so maybe it will be fine?
Any advice much appreciated.
