Electric_Andy
Heavy Metal Fan
- Plymouth
I have analysed the above and deduced your best course of action is to buy a better car….
haha, there's nothing wrong with this one apart from the Bluetooth!
seems to be only for charging? Charging is not an issue...unless I have missed something (which is likely)
What version of BT does the car support?
It would be a base that could support the cable you buy.
No Canbus as far as I know. The head unit is purely maps, FM radio, BT. All the other controls are below with separate knobs which I'm glad about
I've been trying to find out, but can't. I'm assuming (rightly or wrongly) that if it was made before BT 5.0 came in then it might not properly support 5.0 and later. But it clearly does sometimes
No if earlier version it will only support its version and earlier. Thus if car is BT 4.0 then you won’t get anything better than that if your phone for example supports 5.0. BT has backwards compatibility but not forwards compatibility.
This is what I don't understand
Then they will be working under BT 4.0 restrictions not 5.3. Thats the bit to understand. The range will be much lower, the bandwidth lower etc etc
ok got it, thank you. So it would probably make sense to upgrade the stereo to one that supports the most recent BT version possible
The media nav system is pretty terrible, we have it in our Renault (2013 Clio) and it's similar to your issue.
We've got an android replacement (£200ish on eBay) which replaces the whole head unit and frame with a new one, and has a 8" or so touch screen with android auto/apple carplay so it works very much like new cars. Just not got around to actually replacing it yet, so it's in the garage.
Might be something like this but you'd need to check whether you need a new frame around the dashboard or not. Ideally you want something with Android 14 or better. Worth doing a bit of research on what you might need first - a local car audio place is likely to be able to help.
Why 2DIN? You can get some great cheap Bluetooth single DIN radios and if you have a 2DIN slot to fill, 1DIN in top half and you can get shelf thing to take bottom slot eg https://incartec.co.uk/product/Univ...N-Fascia-pocket-50mm-high-with-3mm-lip-50-053 (all sorts of similar available from many suppliers).Thanks, I don't want an android unit though. Just an old fashioned 2 Din will be fine
