Arrived at
Halfords around 2pm. The pads were on the counter with a few other bits, and I noticed an Euro Car Parts delivery note. They had literally just been dropped off. The member of staff first had to book them in, before she could complete the transaction.
Here is the rub. Halfords were £79, but i got discounts that took it to about £67. Euro want £125 a set. I said this to the cashier, you know Euro are over £40 more expensive.
Just started at 2:30 and finished at 4:30 including aquasteel the calipers, cleaning and Buzz Weld lano spray on the bits I've not reached with the wheels on. The app wound the handbrake motor right back - had to dig a little deeper into the maintenance menu to find brake pad change. Had to wind the pistons back until they stopped. Very tight fit getting the caliper back on, literally no space with brand new pads, and a handbrake motor getting in the way. Came with new E10 slider bolts. Not having an E10 socket, I carefully used a standard 10mm 6 sided socket - worked fine as the bolts weren't tight so did back up carefully.
Car started and attempted to activate the handbrake. A few minutes of sweating, various alarms again about ESP, crash avoidance, brakes are doomed, and so are you. Couldn't hear the motors engage, and the app said there was an error. Reverted to the more manual method according to Google and the car's display, Press the brake and keep pushing the handbrake button down - this worked. Tested the handbrake, could hear the motors. Quick drive round the block applying the handbrake, then driving and the handbrake came off as soon as you pressed the go pedal. PHEW. No warning lights.
So, two sets of Pagid Pads and a new OBD reader, £200 all in. Front £50, Rears £70, reader £80.
Old pads weren't bad.
