Car related thread alert! MOT failure.
tyred
Ireland
I'm not afraid to get my hands dirty and have a go at most jobs on the car (see above), and motorbike (dealer charges which make car dealers look like a charity!). However front suspension is something I prefer to leave to those with the knowledge and specialist tools for setting up the alignment and steering geometry correctly.
For the most part, front suspension systems are straightforward to work on and get the alignment checked at a decent tyre centre afterwards.
Brandane
Brandane
Miles cannot be done unless moving!
Ayrshire.
Don't you need clamps to keep the springs compressed when dismantling and re-assembling though?
Last time I had to get an alignment check done (long time ago) I seem to recall it was about £50.. Then there is the MOT re-test at £50+, so it's eroding the savings away already and I still have to buy parts and do the job....
Levo-Lon
Wishbones usually attach to mcpherson struts..front hubs so no danger of spring escaping
they can be easy But ball joints and siezed parts are when the fun starts.
DIY on things like this can be a costely learning curve.
id say 300 is a bargain for 2 new wishbones..
Suspension components I'll let the garage do as the bolts often need a fair amount of persuasion. I'll do all the routine stuff and have the electronic service manual for the car. The only issues I've had with my 2002 Nissan Primera have been air con radiator (holed by road debris), new air con pipe - fractured, and a new cat. Unfortunately each of these jobs were £400-£600, but over the 13 years I've had the car it's not bad.
I do the routine stuff myself, and have done central locking motors on the wife's yaris and even changed the built in 'radio' when it went faulty - dash out job but it's a known issue, and I found a replacement OEM unit on ebay for £25.
Finding a good independent is sometimes tricky. Fortunately we have one very good garage that is very busy and seems to look after just about everyone's cars. I also use another specialist for air con.
Stuff needing big spanners goes to the garage.
There is a known issues with a number of Nissans - whilst the bodywork and underneath is well protected, the radiator support panel isn't - and it can rust to bits. Fortunately it's something I knew about and when it started to corrode, I hammerited the exterior and used spray grease in all the holes and coated the inside. This stopped the corrosion. I do regularly top up underseal on the suspension arms and struts under the car.
Deleted member 1258
I've never learnt how to maintain a car, dispite doing my own maintenance on the motobikes I owned as a spotty youth, now I'm retired and have time on my hands perhaps I should, a course would be a good way of filling a dark winter evening, the learning curve will start this summer though, I have some corrosion to deal with.
Levo-Lon
As above..i hate working on cars now
Vapin' Joe
Formerly known as Smokin Joe
Same here these days. I'm too old to go lying on my back in the cold and wet (Most things only go wrong when it's cold and wet). Simple stuff I'll still do, but even the things that used to be routine like starter motors and alternators are a real pain now as they are invariably accessed from underneath the car.
Levo-Lon
Earthing fault @User9609 it usually is..one of the wires is most likey chafed and touching earth when ignition on..
I had one on my nissan 200..headlight fault..turned out it had been in a bump and a pinched wire..
took me ages to find it..
GrumpyGregry
Here for rides.
My very comfy Rover has recently died. The garage can't work out what's wrong with it. While I'm happy to live without a car for the day to day stuff, I haven't yet found a pannier on the market that will hold a bass guitar and amp. So I am left with the dilemma of going cheap for something with a year life expectancy or getting something better.
Acoustic Image Head and cab, Godin electric bass, and a cargo bike. Sorted.
I used to travel to gigs on the underground....
subaqua
What’s the point
Leytonstone
Funny that, my dad was a mechanic - doesn't bother now, just drops it into the local garage.
Same for my pops too. Although he stopped professional spannering in 1970, when he went on the line at vauxhalls, for a lot more money.
I spent a good chunk of my childhood helping him fix the car we owned. At 12 I could strip down and rebuild a pinto engine and a crossflow ( Kent) engine . Made me a nice bit of money at 17 as mates knew I could fix cars.
