Car tyres, interesting article.
DaveReading
Don't suffer fools gladly (must try harder!)
Reading, obvs
It makes sense. Lots of acceleration and braking (even if not harsh), which is inevitable in an urban environment, will wear out tyres quicker than trundling along at 70mph.
Cornering takes its toll, too. Though technically that's just acceleration, if one wanted to be pedantic. :smile:
That is one I have never heard of, I will have to research it more with some of my customers.
From my experience of 40 years in the motor trade town driving does kill tyres. We maintain lots of local private hire vehicles and they go through front tyres at a very high rate. It is the constant full lock turns they go through.Toe out on turns can cause massive slip angles on outer tyres. Yes they are high mileage vehicles but they go through more tyres than similar mileage vehicles used on motorways etc.
Also from my experience tracking doesn't go out. Suspension joints and bushes wear components get damaged, but tracking very rarely goes out there is usually an underlying reason .
Dirk
If 6 Was 9
Watchet
"Tyres that are used infrequently (e.g. Caravans) and / or in coastal areas will age more quickly."
Just as well I'm replacing my caravan tyres this year. They're 5 years old and it's stored on the coast!
  • Replacing-car-tyres-important-information.pdf
Bonefish Blues
Banging donk
52 Festive Road
Just replaced front tyres on our motor. I noticed one had worn on the outside edge. Bloody tracking had gone out again :angry:
This happens often on current roads I find. If you find a Kwik Fit with a Hunter system (not all have them) then for £99 you can have your alignment checked & adjusted as many times as you like for 2 years.
I know KF have a patchy reputation, but this system features a customer display and print out so you can be sure that your alignment is back to factory spec.
Just a thought, might be useful - it is to me.
Levo-Lon
[QUOTE 4676844, member: 9609"]with tyres; is it riskier to buy a casing from a scrapies or an ex demo 6 month old range rover ?
with the tyre from the scrapies you get to inspect the inside of the tyre, who knows if the RR has been stotted along a rough track and the otherwise new looking tyres are ready to go pop.
If you know what you are looking for second hand tyres can be superb value.[/QUOTE]
agree..as you can see the car there on..
The second hand tyre bay sellers are selling lots of tyres from Germany etc that require changing at mot time as their more strict ..so you have to take the gamble...I'm not against this but I'd be wary of fitting a 4mm tyre of unknown origin ,then using them loaded on a motorway..pot luck or pot hole luck maybe..
All tyres have a date on them..so you can at least avoid older rubber.
I never used road motorcycle tyres that were under 2mm or over 3 yr old.
heat cycles are even more critical once you start using more track specific tyres etc, they go off and then try to kill you..same applies with road rubber..eventually
I sold my 11 year old van in November with the original unused 2005 dated spare tyre ..It looked great but as to its safety? ?
Deleted member 26715
I know that it's generally acknowledged that tyres wear out quicker on cars that are used on short, stop / start journeys, but I had proof of this a couple of weeks ago.
My car (relatively powerful, rear wheel drive, used mainly for 50+ mile motorway journeys) has loads of life left in its tyres after 12,000 miles. MrsR's Mini One has just had to have 2 new tyres after 11,000 miles of mainly short trips.
Apples & Pears
Levo-Lon
Sorry someone mentioned Kwik Fit...:hyper::laugh: no
Drago
The Urban Fringe
Hardly any point in fitting a tyre worn to 4mm. It's 1mm off being Donald anyway.
I'm afraid I, and even the best tyre monkeys, are not blessed with X-Ray vision, or prescient powers. If people can't afford to run a car properly and keep it safely maintained then it shouldn't be on the road. Fitting second hand safety equipment is a daft idea.
Far to many people buy cars that are beyond their means to maintain and run properly - the proverbial champagne car on a coca cola budget. If less people worried about their egos and public displays of brand name willy wagging, they could drive a more sensible car instead and properly maintain it because parts will be a fraction of the price, and other running costs will be cheaper. We've all met someone who scrimped and saved for an M5 [insert alternative name of fast/expensive car here] who then had to put remoulds on it because they were living beyond their motoring means.
Bonefish Blues
Banging donk
52 Festive Road
Here's a funny thing. This equipment is first class, top-of-the range stuff. They train specific people to use it. You get to check that the work's done right. It gets your wheels pointing in the right direction at a very fair price for 2 years.
Of course some may choose not to take advantage of it because of a certain stigma that might attach to a brand. That's their choice.
I have no affiliation to, or love of Kwik Fit, btw.
Brains
Greenwich
Just to remind you of what can happen if you drive on old (not worn) tyres.
Three people returning from the Bestival music festival died after a coach tyre that was 19-and-a-half years old blew out, an inquest heard.
Mr Price said [the tyre] was only half worn so had either been a spare or in storage for many years.
"This is one of the oldest tyres I have encountered failing," he said.
He said recommendations from manufacturers said tyres should not be fitted to cars if they are six years old, and should be replaced if they are 10 years old.
He said that this was not a legal requirement and that it did not apply to coaches or lorries, which was "frustrating".
http://www.bbc.co.uk/news/uk-england-23320526
