Take some website prices if you like and see if they'll beat them.
Mr Pig said:I also think that too many people assume that the tyres that came fitted to the car are the best tyres for it. That's not the case at all. Price, availability, national loyalty all play a far bigger part in which tyres get fitted in the factory than performance.
bauldbairn said:It's a little known fact that some high perfomance cars are developed around a particular tyre.
bauldbairn said:Sorry!![]()
IMO most people don't understand that break away is a progressive thing which if felt can be corrected or used to overcome inadequacies the cars handling envelope.Mr Pig said:In my opinion most people underestimate how important this is. I also think that too many people assume that the tyres that came fitted to the car are the best tyres for it. That's not the case at all. Price, availability, national loyalty all play a far bigger part in which tyres get fitted in the factory than performance.
I'm sorry but you've just waked into trap of your own making... The Honda OE speced A046 will provide great performance over a reasonable range of conditions, dry to medium wet conditions anywhere above 4C. However, & here's the trap, when you get to low temps road surface temps, very wet conditions or roads with mud/snow the A046s will get absolutely murdered by decent winter M&S tyre. Now shall we talk about surface icebauldbairn said:It's a little known fact that some high perfomance / track oriented cars are developed around a particular tyre. My case in point is the DC5 Integra Type R - a car developed around a particular manufacturers "specific" tyre. The tyre in question was the Yokohama A046 which the cars suspension and chassis were fine tuned to use. Any deviation away from these particular OEM tyres compromised performance of what is arguably considered to be the best front wheel drive car ever(2 BTCC wins).
+1... most people don't push their cars to the limit until they actually are confronted with a dangerous & problematic situation... it's a little to late to learn about the performance envelope of your tyres when you get hard on the brakes plus steer trying to avoid the idiot who just pulled across the road without looking properly. I mean, if I hadn't pushed the car to the limit how would I know that you can turn a Cinq sporting on Conti sports contacts really hard under heavyish braking if you ignore inside front lockup & floor the throttle?Mr Pig said:If you drive sedately with good anticipation I guess you might not. However in an emergency the differences could be very real, the difference between life and death, literally.
Mr Pig said:If you drive sedately with good anticipation I guess you might not. However in an emergency the differences could be very real, the difference between life and death, literally. What you suggest doesn't make sense. What you're saying is that it doesn't matter what the tread pattern is, what kind of rubber is used or how the structure of the tyre is constructed, all tyres will behave exactly the same. Even you must see how illogical that sounds?
Rhythm Thief said:Cheap tyres will be absolutely fine almost all the time.
