Carbon Frame Testing
Davideff
Regular
Hi, I recently ran out out of road whilst riding in France. My front wheel dropped down into the ditch (about 600mm, or 2 feet in old money), and I was shot off the front. The bike didn't have an impact as such, and just bounced along behind me until we both stopped. There is no visible damage, but I would like the integrity of the whole frame checked before I continue using it, or I cut it up so no one else can get hurt!
We are both back in Essex now, so if any one has had experience of testing, or able to recommend somewhere (in the SE is best, but its worth it to me to travel). Many thanks. Dave.
Smokin Joe
If there is no visible damage I'd stop worrying and carry on riding. It's tough stuff, not Waterford Crystal.
Anyone who is that worried about carbon fibre is better off not riding one at all.
Basically this ^^^^
I went into the side of a car that pulled out in front of me while I was doing 30mph. I contacted a few specialists and they said they can do ultra sound tests on it, but if there was no visible damage they were 99% sure it was fine.
7500miles later and I think they may be right.
ayceejay
Rural Quebec
Your frame is made from carbon fibre because of its strength to weight ratio and is consequently used in
a lot of application where that is an advantage from racing cars to aeroplanes.
Mr Celine
Discordian
No, you really need to get it checked out. The staff at my company offers a comprehensive service.
Once we receive your frame it goes to Emma, who gives it a close visual inspection.
It's then closely inspected by the superior feline senses of tiddles -
Our photographer Raymond takes a picture (He's looking a bit grumpy - Emma's just dumped him!)
Finally you'll get a written report from these guys.
Yes, for just £100 plus post and packing you get-
An Emma eye scan
A cat scan
An ex-Ray photograph
A lab report.
Or just do what Smokin Joe says.
...as you carry out the tests, it's worth checking that it doesn't dissolve in water. Simply put some fresh rain in a watering can, and sprinkle liberally over the frame. Allow a reasonable time for the rain water to soak in, then check to see if any sections have dissolved.
You may decide to ignore this little test altogether, but can you sleep at night knowing that torrential downpours are forecast for the next few days?........:rain:
Davideff
Davideff
Regular
Thanks for the replies, in particular the more sarcastic ones.......I should have known better than to expect anything else from a bunch of cyclists I suppose!
Just to put it into perspective though, having broken my back & neck in the same accident in Sept, and with a second chance to carry on cycling, (as I managed to get away with no permanent injuries), I'm quite keen not to tempt fate by falling off again in a hurry. Tried it once, and did'nt like it.
Happy pedaling! Dave.
