Carbon will generally be a little more comfortable, but like above, a cheap carbon won't be as stiff as a quality alloy frame.
Look at the stuff Cannondale does with the CAAD frames.
There should be very little weight difference anyway.
If you're a starter then I'd avoid carbon completely. Way too expensive and you might not even get the use out of it.
what makes you think i may not get the use out of it, just because you assume I'm a beginner?
Because you don't really know if you will use it until you actually get it. Kids do it just as much as adults do - they want something then 5 minutes later they don't. I did it with countless mobile phones when I was younger as well, and to be honest now at a week short of 19 I do it still. All I'm saying is, going with alu instead of carbon is cheaper, but if you don't take it up properly, you haven't lost as much money but you've still got a decent bike if you do. I'm not saying get a crap hybrid from tesco, but don't just spend a fortune on a carbon bike because you can.
Having said that, if you want to spend an arm and a leg on a carbon bike, then feel free.
I have ordered a carbon bike, never had a road bike but am riding a reasonable light aluminium hybrid. I was initially going to go alu, with mixed forks, but for a similar difference in price I get the carbon, bespoke build starting with the frame - being a taller woman getting a man's frame, I was always going to need to spend money on changes, such as saddle, bars, stem etc.
I think to do the upgrade, may as well do it properly - all depends if you can afford the difference and indeed can justify it. Personally, I think I will be more inclined to use the carbon bike as much as possible simply because it will feel much more different to the hybrid it terms of ride (and I will force myself to due to the cost)!
OP - I thought you had already made a decision and ordered the bike?
yeah i was the same at that age too but as you get older you learn to appreciate things a lot more, your opinion leans more towards a ALU bike Rather than a carbon, not sure why that is but hey ho as some people have stated on other forums about the weight, IMO its not about the weight its about the stiffness of the ride and if I'm going to be doing some serious miles all i wanted to know, ( not having had a carbon b4 ) is there such a huge difference, from what I've seen so far cannondale make the best ALU bikes with their CAAD series however, i do not like the ride on them..
