Carerra Zelos Road Bike
pedalton
Regular
Hi all,
I have found a used Carrera Zelos which is hardly used. I have sat on the bike at it seems to be the right size for me according to the size guide. Here is review of the bike.
Carrera Zelos Road Bike Review | Best Road Bikes Reviews
I have some mixed opinions and experiences of this bike from the net. A few things I come across is that the tyres are basic and that it has only a 7 speed casette.
Thanks everyone. Really appreciate your help.
biggs682
Smile a mile bike provider
Northamptonshire
Hi all,
@pedalton will the seller let you take it for a spin ?
from what i can see they make a great starter bike , if i have any advice before you start doing to many miles get your local bike shop to give it a once over with some fresh grease on all the places that need it and adjustments where required .
7 speed should be able to upgrade to 8 without replacing wheels but will need new shifters but why worry 7 is enough
P
pedalton
Regular
Thanks all,
My thought on the 7 speed was that I would be limited on wheels if I needed to replace them.
Asking price is £150.
Thanks.
cyberknight
I think they use a 7 speed freewheel rather than a cassette,58 seconds
biggs682
Northamptonshire
Thanks all,
Thanks.
depending on condition and age thats not bad price ?
still easy enough to swap for 8 speed
@pedalton where are you based ?
only asking as i always have a couple of retro road bikes for sale
cyberknight
Indeed, they might need to change the back wheel as well as the shifters /rear mech (?) is all i was referring to if changing from 7 to 8 speed as its another cost to factor in .I know you can get 8 speed freewheels .
Would your retro bikes have more than the gears the OP is after though ?, i know they would probably have a nicer frame but would it be more of a side step than an upgrade?
biggs682
Northamptonshire
@cyberknight i have one running 8 x 2 set up with the older screw on rear block and down tube shifters and another 1 in build that will also be 8 x 2 but with sti's and later style freehub and then the next build should be an 8 x 3 build with either downtube shfters or sti's depending on customer requirements
fatjel
West Wales
I've used one this year.. Has as you say a 7 speed freewheel so changing wheels could get complicated and expensive
That said I've done 5000 miles + since june with no problems at all..
Interestingly the tyres it came with never had a puncture... even when the rubber was worn thru
the schwalbe things I replaced the with tho had loads
craigwend
Grimpeur des terrains plats
My friend has one - a good starter bike - he has done a couple of sportives with no problems & regularly uses it for commuting & fitness rides.
I wouldn't bother upgrading much ( I think he has with tyres & pedals to clipless)
wait till you get the bug & a 2nd (then 3rd) bike :smile: ....
