Carradice Bagman Seat Stay Struts
Heltor Chasca
Out-riding the Black Dog
I remember someone on here putting up some photos of their Carradice bagman rack showing some stays attached to it. I can’t find the post anywhere. I thought it was @ianrauk but he denies owning canvas luxury. As I have a small frame I also have the same problem if I load up for a long weekend, the weight can bounce and hit the mudguard.
If it was you: What parts did you use to join the stays to the rack? (At the T junction)
I think you have made a brilliant solution and if you don’t mind I wouldn’t mind copying your brilliance!
Please own up. Thanks.
Nibor
Bewildered
Accrington
Theree is a Bagman 2 which appears to have built in support https://www.fawkes-cycles.co.uk/648259/products/carradice-bagman-2-standard-sport.aspx
andrew_s
Gloucester
Carradice sell support struts for the standard Bagmen
https://www.carradice.co.uk/products/accessories/bagman-support-strutts
The Bagman 2 has been dropped and is no longer available except as NOS.
The support was aluminium rather than steel, and had a tendency to fatigue & break if used with a heavier load.
Having said that, my reaction to the bounce was to wrap a strip of rubber mat (found at the roadside) around the rear of the support, secured by a couple of zip ties.
Heltor Chasca
Heltor Chasca
Pressed the button! I bought the struts from SJS. Beautifully machined parts. Thank n fitting by them it appears there is a spare triangle of space to attach a mat or something. It is also very neat and tidy. I have a decent ride coming up to trial the set up. Thanks all.
