Cassette change on my road bike
beatts
Leeds
Hi
Would I benefit much from swapping out my 12-25 cassette to a 11-32(on my road bike) in respect to making hill climbs easier.
would this be a straightforward change (9 speed for 9 speed Shimano)?
thanks
adscrim
Perth
A shimano road rear mech won't take a 32t cassette, max suggested is 27 I think. If you want to use an 11-32 you would need to swap out the rear mech for a MTB one.
Herzog
Swinglish Mountain Goat
Shimano do long cage road mechs (at least 105 and Ultegra, as that's what I use). You would benefit greatly from the change, being able to spin up most hills with ease (depending on your ability of course).
You'd also need to replace the chain; the one you're currently using will be too short.
B
beatts
Leeds
Ok thanks for the info!
It doesn't seem worth if it if I won't gain that much. I'll just work on my legs more
Nebulous
Aberdeen
I'm on 9 speed shimano and went from 12-25 to 11-28, with a bit of fiddling with the b screw.
The bigger jumps between gears were an inconvenience for a start, but I soon became used to them.
rockyraccoon
... It doesn't seem worth if it if I won't gain that much. I'll just work on my legs more
You will. There are some hill which I had to stop and push the bike. I never minded that, but after a few times it started to spoil my rides. I decided to change my from 12-26 to 11-28. What a difference! Hills are not a problem anymore!
B
beatts
Leeds
"I decided to change my from 12-26 to 11-28. What a difference! Hills are not a problem anymore! "
Wow really just an extra 2 teeth made that sort of difference?
mcshroom
Bionic Subsonic
Surprisingly yes it does.
You should be able to get 28t to work with your mech just about. If you are worried about spacing them maybe go for a SRAM cassette as the gears at the top end are closer with big drops for the bottom gears, rather than a more even spread across a Shimano one
