Bit of both I believe. The ceramic layer doesn't get worn away as quickly as alloy would, and it's rougher, so the brake blocks grip better IIRC.
You do need to use special brake blocks, as normal ones get abraded away quite rapidly.
Bit of both I believe. The ceramic layer doesn't get worn away as quickly as alloy would, and it's rougher, so the brake blocks grip better IIRC. You do need to use special brake blocks, as normal ones get abraded away quite rapidly.
I'd be surprised if they didn't - sure I've seen them reviewed somewhere.
*checks a few on-line bike shops* Wiggle do KoolStop ceramic pads, but for V-brakes. I can't remember what brakes you have...
I used to have them on an old MTB of mine, I seem to recall braking on them doesn't produce that horrible 'grey blood' that gets everywhere when you mend a puncture!
I have ceramic rims and use the specified Koolstop ceramic pads with these. Being so hard the rims will eat normal pads. My rims show no sign of wear after many years and it's a pity that they're so expensive.
