Chain Comes off
Downward
West Midlands
My chain comes off a lot maybe once every 5 miles when I am changing the front gears.
Tonight it did it and threw all the gears out so I had to plod on home with my gears rattling and changing up and down.
rich p
ridiculous old lush
Brighton
Does it come off on the inside or outside? There are 2 limiting screws on the front derailleur which stop the chain going too far either way. You need to adjust at least one of them.
Downward
Downward
West Midlands
Inside - I adjusted it as it wouldn't go on the biggest ring. Could do with a chain catch or somthing
johnsie
Norfolk
Could be the same problem I had, the large and small rings were not quite bolted together as snug as they could be, and there was the equivalent of a wheel buckle in the large ring - every so often pushing the chain from one ring to the other would coincide with the "buckle", thus going too far and dropping off - any help?
Globalti
Make sure your chainrings are not loose.
If it's dropping off the inner chainring, consider the length of the chain. I had this problem recently and I got lots of advice on here but in the end shortening the chin by 2 links almost resolved the problem.
02GF74
check that the derailluer cage is parallel to the chain rings - it can be knocked out of line quite easily.
cyberknight
And it is set the right height above the chain ring , i had this same problem and cured it by dropping the mech till it was a coins width above the chain on the upper chain ring
http://bicycletutor.com/adjust-front-derailer/
