chain issue
mynydd
Hi,
Anyone else had this?
I've a new bike (boardman ADV, not that that particularly relevant)
It was fine for the first week but suddenly I have an issue when changing down onto the smaller ring at the front. The chain jams, and when I say jam I mean really jams, I have a job getting it unstuck . On closer inspection it looks as if two of the links jam at right angles to each other. But I'm at a loss as to understand why.
Indexing etc. is all fine., as is lubrication.
Is it as simple as a faulty chain? or is something else going on?
Thanks
Pale Rider
Sounds like a stiff link, which can happen for no apparent reason.
You could try a squirt of lube and 'working' the links to free them.
Threevok
Growing old disgracefully
South Wales
Is this happening where the chain was connected ?
This can happen if connector pins was not inserted properly or the wrong size connector pin was used
Step 6 of this chain tool description is the key bit, where the pin is pressed back a tiny amount with the chain 'floating' in the chain holding slot closest to the driving pin in the tool.
That said, on a new bike, and if you don't have, or don't want to fiddle with, a chain tool, get the shop to fix it, as I Like Skol says.
mynydd
mynydd
Thanks all. You've confirmed what I thought - a faulty chain..... or chain set up
unfortunately I bought this one online from cycle republic, so cant just pop it back. Have emailed them requesting they send me a replacement chain ASAP
Cycleops
Accra, Ghana
If you do get a replacement fine but just working the stiff links with some lube will free it up .and give you a spare chain .
Cycleops
Accra, Ghana
agree, but shouldn't have to with a new chain should I
Stuff happens.
I like Skol
A Minging Manc...
Not if the links have been set too tight at assembly. If this is the case they will always be problematic unless mechanically eased off to increase the clearance a little. This should not be necessary on a new bike but stuff happens (cross posted with Cycleops :laugh:). It is one of the dangers of buying online, unless you have the know-how and tools to fully commission the bike yourself it can be a risk.
mynydd
mynydd
Update : following a closer inspection during my coffee break I discovered a small nick in the smaller chainring (presumably caused by a pebble) that was catching the chain and causing it to jam....... borrowed a file from the workshop, and two minutes later problem sorted :becool:
Thanks for all the input
wisdom
Blackpool
Just a thought.Could the chain not have caused the nick due to it jamming.The sticking link still needs to be sorted in my opinion.(just my thoughts).could you pop a photo up of the link that's causing the problem.
mynydd
mynydd
Yes, good point.... however it was whilst looking for the dodgy link, which I was unable to, that I found it. whilst rotating the pedals slowly I noticed the chain sticking to it every few rotations...
I'll ride it home this evening, and see how I get on
Thanks
