Chain lube
Tommohawk
Does anyone have any experience with Squirt or Fenwick all conditions chain lube? I've been using the muc-off lube since I began cycling but it causes alot of mess to the drive train and I'm looking at these alternatives.
Dirk Van Der Dirk
Fenwicks is great. Not had any issues with using it daily on my commuter in all weathers.
Widnes
Dunno how sensible it is but last time my LBS looked at my bike he told me to start using GT85 and nothing else
starting with a clean degreased chain then just using that on chain and gears
he said the PTFE from the spray is all it needs
any opinions??
EDIT - oh - and he said to be careful to avoid the disc brakes with the spray - he said he has had a few back that need the disc cleaning and sometimes pads replacing!!
13 rider
leicester
Used squirt in the past does keep your chain much cleaner than oil based lubes but does wash off easily if you ride in the rain . Currently using Silca drip on wax much more expensive same properties as squirt in keeping the chain clean but lasts longer even in the rain
any opinions??
Pedal swiftly away from your LBS before he gives you any more stupid advice.
