I think drink beer, ride and take photo's would be more entertainingIt is not distance related. You can soil a chain with one shorty dusty or muddy ride or you can keep it clean by cycling 600km on clean moist roads.
Clean it when it is dirty. Oil it when it is dry. Ride bike, drink beer and take photos.
Hi, just fitted a quick link on my boardman cx comp. how often would you guys recommend removing the chain and thoroughly cleaning? I cycle on average 20-30miles a week on reasonably decent roads.
Cheers guys I think the ride/drink beer take photos sounds like a great idea.
Also just out of interest how often would you remove rear cassette completely and clean each individual ring? Or can a thorough job be achieved whilst it's still in place?
I find that any lube regime causes the gunk to build up and solidify between the cassette sprockets (gave up on 'dry lube' after a couple of rides because of drivetrain noise and lack of lubrication!). The rear derailleur jockey wheels also get the same build up which is then shaped by the chain and derailleur side plates to form a big, double thickness jockey wheel. This can also be scrapped off with the screwdriver/bamboo skewer while slowly turning the pedals backwards and drops off in big, black, oily lumps. Just be careful where you do this and don't accidentally step in the mess and then tread big, black, oily patches all through the carpets in the houseI use those bamboo barbeque skewers to scrape the gunge out but if you 'oil and wipe' it doesn't get too bad.
I find that any lube regime causes the gunk to build up and solidify between the cassette sprockets (gave up on 'dry lube' after a couple of rides because of drivetrain noise and lack of lubrication!). The rear derailleur jockey wheels also get the same build up which is then shaped by the chain and derailleur side plates to form a big, double thickness jockey wheel. This can also be scrapped off with the screwdriver/bamboo skewer while slowly turning the pedals backwards and drops off in big, black, oily lumps. Just be careful where you do this and don't accidentally step in the mess and then tread big, black, oily patches all through the carpets in the house![]()
Monthly, depending on how well you clean it 'normally'.
