Chain rings worn?
mynydd
Can anyone advise if these need replacing? I fitted a new chain, and it slipped, so I assumed I needed a new cassette. But when I looked at the chainring it seemed worn to me, can anyone confirm? Thanks
Citius
Yep - not looking too clever...
mynydd
mynydd
Thanks. Any suggestions as to where to get a replacement online? Will any shimano chainset with the same size rings fit? I only seem to be able to find 10 speed versions, mine is 9 speed, does this matter?
Many thanks again
si_c
Wirral
Many thanks again
Which chainset is it?
si_c
Wirral
You should find that any chainrings from shimano fit with the same BCD (bolt circle diameter), you will need, outer, middle and inner if you wish to replace all three. Outer and middle will be 130mm, inner should be 74mm (see here http://bit.ly/1UgxnJ4). You should be able to get them online easily enough (SJS cycles has a good search tool for this, far better than e.g. wiggle).
See below for some possibilities.
Outer: http://bit.ly/1mRjV43
Middle: http://bit.ly/1YOttxK
Inner: http://bit.ly/1OkT2jf
mynydd
mynydd
Ah, so I only need to change individual rings? I didn't realise that, thanks. Should save a few quid
lpretro1
If you use a 9 spd chain on a 10spd it will not be so good as the 10spd chain is narrower. You will find it is cheaper it buy the whole chainset rather than individual rings - you need Sora which is 9 speed
mynydd
mynydd
Sorry if I'm being stupid, but why sora? My current set up is tiagra and its nine speed.
Thanks
mynydd
mynydd
Ah, I see. Many thanks
So if I buy a sora triple, with the the same size cogs, it'll just fit in?
Sorry for all the daft questions
