Older chainsets were mainly 5-arm. The newer Shimano ones are 4-arm.
Once you know the BCD then the only other question is do you need a chainring with 'ramps and pins' to help the chain climb onto it when you change gear or not.I have an unfortunate idea at the back of my head that it's not always a simple question of matching the BCD.
Or did I imagine it?
Isn't there a bit of leeway on that?One more thing you need to check is that the chainring is for the correct speed of chain.
Yes, but it won't do any harm to check. Spa are really good.Isn't there a bit of leeway on that?
As in this:
https://www.spacycles.co.uk/m2b0s109p2000/SPA-CYCLES-XD-2-Touring-Triple-Chainset
Says 7, 8, or 9.
Mine's on a 9 speed build.
