Chainset advice please
cd365
Coventry, uk
This year I have tried to change my riding style from grinding a big gear to one of a high cadence. I have a compact Shimano 105 50/34 chainset and just tried to use the 34 ring spinning a high cadence. This has worked in that my legs don’t feel as tired all the time on my commute.
On my rear cassette I run an 11/23.
Recently I have been thinking of changing my chainset to a 53/39. I think the 39 might be a bit better for me since I easily pedal out (I try not to change into my big ring because I know I will just stay in it; it’s a mental thing). I’m assuming that I would need to raise my front derailleur and buy a longer chain, how long should the chain be? I don’t think I would have to change the bottom bracket?
Another option would be to run a 50/39 just changing the 34 ring to a 39 ring. Stupid idea? I do like the option of being able to run a 50/34 or 53/39 at will (well just by changing the chainset and chain).
Any advice/opinions welcome. Thanks
cyberknight
I changed my inner to a 36 , seems to work nicely .
Im not sure you can change the inner to a 39 anyway but it depends on the BCD of your chainset, most compacts 110 bcd can run a 52/36 max and then you have the 130 bcd for 53/39 .
These new fangled one size bcd that has just come out im not sure on .
cd365
cd365
Coventry, uk
My BCD is 110mm; a Shimano 105 FC5700 50/34t
I might look at a 36 if I can find one suitable.
I think it might just be easier to buy a 53/39t Chainset!
Citius
Most ring sizes are available in 110bcd. The logic of what you are trying to achieve is an entirely different thread though....
If you get the chance have a look at the ceramic bearing based BB's - I use a GUB Hollowtech II type BB - as they offer a slightly smoother operation which is ideal for high cadence pedalling.
gbb
Peterborough
I dont know what the terrain is like in Coventry but here in Peterborough we have a choice of flat Fens or gently rolling hills of Northants. My last two bikes came with compacts and 11-25 IIRC, wholly innapropriate for round here so I always ran a 50/40. It worked brilliantly for me, only need to change the dog fang position if ones fitted.
£15 at the time for a 40t, 15 minutes to fit and you're away. Its just finding the right one between 34 and 40(which is the maximum inner I think)..to suit your terrain.
Citius
I used to run a 42 inner, so I doubt if 40 is the maximum. Also, ignore anyone who tells you there is a quantifiable benefit to running ceramic bearings.
Citius
I would be interested in your thoughts.
I cycle around rolling Warwickshire countryside.
Well, the cadence thing bothers me a bit. It should really be self-selected, rather than forced. If you are forcing yourself to spin easy gears at unnecessarily high cadences, then you are unlikely to be riding to your full potential - and there's no particular benefit to artificially high cadences anyway.
mythste
Manchester
Interesting advice, but it appears to me that OP has spent a long time grinding out too big of a gear, so "artificially" high cadences to him may well be more in line with a "normal" cadence day to day.
At least that's how I interpreted it!
cd365
cd365
Coventry, uk
I tended to sit in a high gear and spin a cadence of low 70s. This often left me with tired thighs. I decided at the start of this year to try and change my cycling style, i.e. a cadence of around 90. To do this meant that I was better off sitting in my smaller ring, the benefit of this has been that my tired are a lot fresher and I can now easily cycle 20+ miles 7 days a week (20 mile a day commute and a couple of longer rides at the weekend).
I do think that I would benefit from increasing the size of my small ring from 34t to something bigger so I get the full benefit out of my rear cogs, I rarely use the first 4.
The only downside to a higher cadence is that I am slightly slower but if/when I want to I ride in my 50t ring and put a faster ride in, I did it a fair bit at first but am doing it less and less, the only downside is that I have no real Strava improvements this year!
ColinJ
Puzzle game procrastinator!
I dont know what the terrain is like in Coventry ...
Ideally suited to a 53/39!
I made do with a 53/39 on my best bike up here in mega-hilly Yorks/Lancs for a long time before finally conceding defeat and sticking a triple chainset on the bike, but I had no problems with it in Coventry and the surrounding area.
