Hi all, lately my chainset has started making creaking noises when I pedal hard. The chainset has two riveted rings, so no bolts to tighten.
Would it make sense to try to hammer the rivets to see if that helps, or are the noises likely to indicate that I should think about getting a new one? The rings themselves are not worn, probably quite a lot of life left in them.
Thanks for your help.
