livpoksoc
- Basingstoke
I've been toying with trying to change the spec of my old road bike, to be near enough a hybrid so I have an alternative to the roady.
After a quick test of getting a 32mm tyre onto said road bike (Spesh Secteur Elite), the only issue in terms of space was the brake callipers rubbing the tyre, otherwise the frame appeared to be able to take the wider tyre.
What I want to know, is is it at all possible to change from a Caliper brake, to either cantilever or V brakes to avoid the rubbing? Is it a case of buying the correct levers, cables and brakes and replacing them, or are there any glaringly obvious pitfalls that I am not aware of? The bike had drop bars as is - would these also need replacing to accommodate the correct levers?
My cheapish shopping list to do this on a budget would be the below. If it's not really worth doing then I'll be looking at getting an entry level hybrid/touring bike which I'd rather avoid as space is also an issue here.
Tyres: http://www.chainreactioncycles.com/schwalbe-marathon-touring-tyre-greenguard/rp-prod69133
2 x £15.99
Brakes: http://www.chainreactioncycles.com/shimano-deore-t610-v-brake/rp-prod107375
2 x £17.99
Levers: http://www.chainreactioncycles.com/shimano-deore-t610-trekking-v-brake-levers/rp-prod108828
1 x £20.49
2 x £15.99
2 x £17.99
1 x £20.49
