Or simpler still, stick with the same brand ideally and it will be straight swap. You might need to shorten the chain a bit too.
Would there be any problems with front derailleur clearance with the larger chain rings?
Or just stick bigger rings on the existing chainset.
Assuming its a standard compact then it s should be able to run a 52 , i have seen 54s at sjs cycles with 110 bcd too .What's the rear cassette? If it goes to an 11 sprocket, then a 50t front should be fine. You will have 120" gear with a 50x11, which is a biggish gear.
