Changing disc brake rotors.
Banjo
Fuelled with Jelly Babies
South Wales
The discs on my Trek Valencia hybrid seem to be rivetted onto the flange.They dont need replacing just yet but how do you get them off when they do?
Steve Austin
The Marmalade Kid
Mlehworld
you need to remove that splined lockring on the hub.
a cassette removal tool is the same size.
happy fettling
Banjo
Banjo
South Wales
happy fettling
Does that mean I have to replace the complete splined flange arrangement or can I drill it off once removed from the bike?
Armegatron
happy fettling
OOoooh I didnt know they were the same size...:ohmy:
Guess what Ill be doing tonight B)
monkeypony
You have centre lock rotors. You should replace them with new centre lock rotors.
They are not designed to come apart.
Banjo
Banjo
South Wales
Ok cheers. Just had a look on chainreaction and they have them on there.Pity there not bolt on ones at half the price but never mind its only money B)
Banjo
Banjo
South Wales
happy fettling
Thanks for the tip, at least I wont need to buy another tool as well then.
There not ready for replacement yet but looks like I have to start saving my pocket money.
battered
Strange layout. Never seen that before.
The wear rate on discs is minimal, loads less than on rim brakes so by the time you have worn this out the chances are the hub will be worn out and the spokes will be halfway worn through, so you'll be in for a new wheel and you can have any discs that fit it.
I've only worn out 2 rear wheels in 15000 miles of on and off road riding so you may have some pedalling to do first!
Banjo
Banjo
South Wales
i should think the wear rate on brakes would depend on how hilly the area you ride.
battered
I'm sure it does, amongst other things. My mountain bike brakes wear fastest when it's wet and muddy and everything is filthy. I once wore out a nearly new set of rim brake blocks on a sopping wet ride round Otley/Harewood, and my discs last longer but take a beating when they are full of grit and mud. Then again, everything suffers when the bike's up to its axles in muddy water.
Banjo
Banjo
South Wales
I guess theres loads of factors afecting the brake wear ,I dont do much off road apartfrom a few rough track shortcuts now and then and the odd gravel road.Looking at Steves link there not that expensive anyway .
Thanks to everyone for the replies.
