chip pan fires, if caught straight away are actually very easy to deal with as long as you don't panic. Fires need 3 things to survive. fuel, heat and oxygen. remove just one of these things and the fire dies.I think more people die in fires caused by falling asleep with a cigarette. But they are smouldering fires, not quite as dramatic as a chip pan flash.
turn off the heat. wet and wring out a tea towel, place tea towel over top of chip pan to smother flames... orplace a plastic tray on the chip pan as the heat melts the plastic and "seals" the chip pan, thus no oxygen can get in.
If you don't catch it straight away, your cupboards catch fire and then the fire takes hold like most normal fires, even at this stage the fire service could probably save the rest of your house. you get the "flash" when you chuck a cup of water on it... which people do when they panic, and then your whole kitchen goes "Wooooooooooooooooooooofffff" and you most probably die, and by the time the fire service get there your whole frickin house is on fire.
so thus you should not cook chips when in danger of falling asleep and also don't panic.
another bad thing to do is run outside with the chip pan and throw it. that doesn't work and will probably singe your eyebrows off
