Chorus 11sp cassette pricing
winjim
How come there is such a difference in price between Campagnolo Chorus cassettes? A 12-27 is a modest £70ish, but a 12-29 is about £100. Thirty quid seems a lot to pay for two extra teeth. Is it simply that the less popular combinations are more heavily discounted?
Pro Tour Punditry
To add to the confusion, here's Ribble's prices for different 11-speed Chorus cassettes
11-23 £87.95
11-25 £87.95
11-27 £99.95
11-29 £99.95
12-25 £72.65
12-27 £72.65
12-29 £87.95
winjim
winjim
So that makes my 12-29 a bit cheaper than at Wiggle, but there's still weird differential pricing. MRRP is >£100 so they must be applying some sort of discount system :wacko:
Any narrower range than 12-29 imo defeats the point of having 11 speeds so maybe they're less popular and therefore cheaper?
The benefits of a narrower range on 11 speed are tighter steps between gears (less teeth). Far more efficient. If you are OK climbing with say 12-25 then stick with it rather that 11-29.
winjim
winjim
Yes, but the effect is much less than it would be on a lower speed cassette. Team Sky, for example, use the same cassette throughout a whole grand tour, where previously they would have changed them between stages.
For me the advantage of 11sp is that you get the benefit of wide rage and close spacing. I guess time triallers would maybe use an 11-23 11speed cassette?
I used to swap sprockets etc. Used a straight through block (cassette) for TT's - 1 tooth increments, then switched to a block with a couple of climbing gears for long rides/hills.
Sky will swap cassettes regular. as do all pro teams - they actually swap wheels. I don't see the point in having dinner plates on the back unless you need them.
winjim
winjim
Yes, I get your point about TTs.
Not according to this article
http://road.cc/content/news/122772-tour-tech-2014-chris-froomes-team-sky-pinarello-dogma-f8
There's probably a lot to be said for having consistency in your setup.
I run a 13-24 and 39-53 on both my road bikes. No need for any bigger. If I had 11 I'd run about the same config, but a closer tooth spacing.
Don't believe half the crap that comes out. Most pro teams will change cassettes between each day depending upon terrain, and even mechs - SRAM wifly stuff comes out for some of the Giro stages
