SteveParry
- WIRRAL
And actually the "MINIMUM INSERT@ I I I I " defined depth should be no higher than the top of the threaded steerer tube, not the top of the lock nut.yep, the minimum insertion line is there for a reason![]()
really?And actually the "MINIMUM INSERT@ I I I I " defined depth should be no higher than the top of the threaded steerer tube, not the top of the lock nut.
Cinelli make parts for racing bikes.... it doesn't seem very high for a stem.
Nitto do a stem that goes higher if you want to be safe...
