I have been having problems with a Claris front derailleur and shifter. This is on a Giant Defy 5 and is the standard type shifter not the thumb one.
It has never shifted properly from new, so I tried to adjust it using the videos/guides/Shimano docs, however the shift from small to large feels wrong, the chain appears to push against the large ring and jam a little before shifting up.
When reading the Shimano docs, it appears there are 4 positions: Small, Small Trim, Large Trim, Large
It then goes on to appear to show that shifting from Small to Large should go: Small, Small Trim, Large, i.e. only 3 lever movements. In the other direction similar, Large, Large Trim, Small. Is my interpretation of the document correct? http://si.shimano.com/php/download.php?file=pdf/dm/DM-GN0001-09-ENG.pdf
If it is, the shifter appears to shift from Large to Small exactly as described, 3 clicks. However, going from Small to Large is 4 clicks. What is wrong?
