So cycling to work yesterday and as I go to unclip my foot just slides out rather than releasing. I check and there is a bit of wear on the side but otherwise they looked ok. Cycling home in the evening I take it easy to avoid my foot flying out as it is only the side that has worn down and the front is remaining solid against the pedal. Having learnt from previous experience where it has flown out only for the pedal to crack against my heel.
Now I know I'm no prima ballerina and at 6'4" and quite broad (aka a bit tubby) I probably put a bit of wear through the cleats but I seem to go through mine quite quickly. I would hazard a guess that I walk about 300 metres on them each journey to work, although half that is carpeted. I may well start putting trainers in our bike shed and just change in to them when I pull up. I know that wear is likely to be uneven due to resting on a preferred foot but was wondering what other peoples experiences are and any tips for extending their life.
I know they're not expensive at £10-20 but any pointers would be welcome.
