Ive looked on you tube but its not very clear on it, any recommendation on a make.They're just awesome. It'll put 120psi in my 25mm, lower for wider. Basically, it'll fully inflate whatever you have in about 2 seconds. Carry spare cartridges and bobs your proverbial
I've got the same one and echo everything MattHB saysAnything really.
I have one of these and it's perfect. I like the lockable trigger and the fact that it takes threaded and non threaded cartridges so I have buy whatever's cheapest on eBay.
http://www.wiggle.co.uk/genuine-inn...innovations_Ultraflate_Plus_CO2_Tyre_Inflator
Depends on the size of the cannister and the size of the tyre, all eg 12 g cannsisters should contain the same amount of gas, a road tyre being narrower will get up to a higher pressure than a wider MTB tyre .Lol, SOLD ill be ordering one tonight then.
Do all cannisters go to the same psi ?
So for a 700 x 25 i should get a ?Depends on the size of the cannister and the size of the tyre, all eg 12 g cannsisters should contain the same amount of gas, a road tyre being narrower will get up to a higher pressure than a wider MTB tyre .
I think ffoeg has it covered !So for a 700 x 25 i should get a ?
Looks like i should have gone for 12 g rather than 16 g as 130 psi is a bit much but i suppose it gives a bit of leeway if i do not get the head on properly.
As for pumps i nearly bought the one everyone else has but i bough a weldite as it got good reviews in a cycling mag but only takes threaded cartridges .
http://weldtite.co.uk/products/detail/jetvalve-co2-tyre-inflator
Anything really.
Do you use the GI cartidges only or any make.
