The vid is not misleading - in fact it couldn't be more straightforward. It is intended to highlight the differences in breaking force and that's what it does.
the carbon bike starts delamanting dangerously at the same forces an alloy bike starts necking the tubes,
That's one hell of an assumption. Unless you have access to some specific post-test analysis data that is not contained in the video, you simply don't know that.
Did you even watch the video? you can physically hear it when the carbon frame goes beyond 900 lbs.
"hell of an assumption"![]()
I watched the video and heard the noises. Unfortunately, I lack your level of scientific insight, which enables me to pinpoint the precise origin of the noises and identify the precise reason for their occurrence. I also lack your level of scientific conjecture which would enable me to predict the outcome should the frame continue to be ridden.
Your attempts to hide your mistake through a beefed-up vocabulary don't impress me. You would certainly hear those noises if you knew I wasn't asking you to listen to them.
Pardon? What mistake? I said I did hear the noises.
Yes, but youre deliberately misinterpreting them
Pardon?
I'm calling them 'noises' and not attributing a cause to them, as there is no obvious evidence. You, on the other hand, are attributing a very specific cause to them with no obvious evidence - other than your own assumptions.
So, which of us is 'deliberately misinterpreting'..??
No obvious evidence? Did you literally just call hearing those noises no obvious evidence?
Lol oooooooooooooooooooookaayyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy![]()
and at the same pressure the carbon frame starts delamanting internally - you can hear individual fibers breaking away, this wouldn't make it safe to ride in the test of time, though that can vary.
Evidence of a noise is evidence that there is a noise. It is not evidence of anything else. It certainly isn't evidence which justifies your highly detailed analysis below. Unless, as I said earlier, you have access to some kind of test data that is not contained within the video. Which I seriously doubt.
No offence mate, but you'd make a sh1t scientist.
so when you hear a loud distant bang on the 5th of November you wouldn't believe it's a firework until you saw a guy in a lab coat giving you sheets of data?
And trust me, i'd make a better scientist than a scientist that doesn't operate with the great laws of common sense. You're only arguing this because you know i'm right, and it's shameful that you can't even bring yourself to admit when you're wrong. Hide behind this "oh but i dont have enough data" all you wish, but it won't work because if you know even a pennys worth about carbon, you know what that noise would be.
There you go then. Expert conjectural scientist has spoken. Meanwhile, I'll stick to the facts, if that's ok.
I'm not a scientist, I just own a brain and an average set of ears.
sucks that not everyone even has that, huh.
