TheCyclingRooster
- Scarisbrick,Lancashire
Hi to you all out there. What is the maximum number of teeth that can tolerated on a compact ?
Is there a formula whereby the tolerance range changes with a large ring - say 52T or a smaller yet still the larger of two at say 46T.
If the inner of two was only a 24T or perhaps a 26T would would the outer then be ?
Is the Compact governed by the ratios on the cassette ?
