Correct angles for rear gear changer
Old timer
Norfolk, UK
I`ve been experimenting with different chainrings on two bikes. Increasing the the size. (single front chain ring) I`ve added the same amount of new chainlinks as the increase in ring size( 48T-55T added 7 links)
Is this correct?
Also I can`t seem to find any decent images or diagrams as to how the rear changer should look when you have the chain length correct. ( say the angle of the two main sections) Any links?
Thanks
gbb
Peterborough
'The best technique for setting chain length is to thread the chain onto the large/large combination, without running it through the rear derailer. Mesh the two ends on to the large chainwheel so that they could be connected (outer link meets inner link), then make the chain one complete link (one inch) longer than that. In almost all cases, this will give the optimum length.'
Taken from ...
http://sheldonbrown.com/derailer-adjustment.html#chain
hubgearfreak
Is this correct?
no, if you go from a 30tooth front ring to a 50 tooth one, you'll need 10 more links, not 20. the chain is only on one half of the chainring at once.
unless you've fitted the chain really wrong.
Old timer
Old timer
Norfolk, UK
Yeh! but doesn`t the new diameter of the larger chainring pull the chain forward by more than half it`s circum?
So! changing from a 48-57 means a increase of between 4 or 5 links then rather than the 9 I`ve added? and adding too many links will give chain sag?
Are you counting a link as 1 where one tooth can go in or 1 where you get both types of link( apair)
Old timer
Old timer
Norfolk, UK
Taken from ...
I`ve looked at Sheldon page and drawings, I still find it hard to take in that a chain run around the largest rear cog and then onto the chain ring + 1" will be enough chain to also thread through the gears. I understand that the smaller cogs take up less chain but you still have to have adequate length of chain to go onto the largest cog and through the gears:wacko:
I`m obviously missing something
Hacienda71
No it is right. Tried and tested, I know it seems odd but it is the easiest way of doing it correctly.
gbb
Peterborough
It does work...honest :becool:
I followed those instructions to the letter when i built my winter commuter from scratch. Its been running correctly ever since. I know what you mean about it then running through the derailleurs, it doesnt look right at first, but it'll be ok.
Smokin Joe
Old timer
Old timer
Norfolk, UK
Right, I know better than any long term tried and tested method:blush:
So! I did as the diagram said, waitng for everything to sieze up, just did 5 miles changing gears at will and you are right! it`s works:biggrin:
Now to repair the second puncture in two days( rear this time:-(
