Creaking bottom bracket on newish bike
ClaireSaud
Hopefully I don't sound daft posting this .............. I bought a new Orro Terra Via in September last year and it comes with a Token PF30 bottom bracket. Since December it has been creaking, steadily getting louder. I took it back to my LBS today and they removed it and regreased it. They thought I had jet washed the bike, definitely not! I am concerned because I've only covered 1600 miles on the Orro, commuting to work and back on roads. Should I expect more mileage before having to regrease it or is this something I will have to deal with every few months please?
Not unusual, I would say. If you look at the bearings themselves and see how exposed they are, then you will not be surprised at how vulnerable they seem to be. getting a good barrier of lithium grease will help, but in today's world a bottom bracket bearing is a short-lived consumable. It is very hard to keep water out of a bottom bracket unless you only ride in warm, dry conditions, and where is the fun in that?
ClaireSaud
ClaireSaud
Thanks for all your replies, you've been most helpful. Time to get myself trained and tooled up to regrease it regularly. Thanks again
boydj
Paisley
My Focus has the PF30 bb, but it has remained quiet so far. From my research on the subject the adapters required for a 24mm Shimano chainset are all problematic, including the Token one. The Praxis Works adapter seems to get the best reviews, but it's expensive.
cosmicbike
Perhaps This One.....
Egham
PF30 on my Boardman CX lasted less than 1000 miles before creaking. 20 minutes spent stripping & re-greasing has left it nice and quiet for the last 4000 miles.
StuAff
Silencing his legs regularly
Portsmouth
Zero creaking on my Litespeed's PF30 in many miles since it was built up in October 2015. Wheels Mfg BB, as specified by Litespeed on their own complete bike builds.
ClaireSaud
ClaireSaud
Thanks, I just took a look at the Praxis. I'll wait and see if it starts creaking again and maybe consider the adapter. At least I have a plan B, cheers
Pale Rider
Cannondale released a technical bulletin to fix creaking press fit bottom brackets because they had so many.
If I recall they specified which grease to use, but that was all it came down to - grease it.
The manager of my local bike shop is no fan of press fit bottom brackets, but he says they give a reasonable service life on a road bike, provided you can put up with/sort/don't get the creaks.
Press fits are a dead loss on a mountain bike due to mud and grit ingress.
All of which reminded the shop manager of another brand which had a short bottom bracket locating tube which pushed into the bottom of the seat post.
Nearly every one creaked.
The manufacturer fix was to dribble linseed oil into the top of the seat post, the thinking being it was runny enough to run down the tube, but thick enough to hang around when it reached the bottom.
And, as the manager told me, the bike smelled nice.
Might be worth a try with a creaking press fit bottom bracket if you cannot be bothered to dismantle and regrease it.
