Can someone explain why Cycle Lanes end at pinch points and re-start after? I would have thought the pinch was were you needed the lane to show drivers to hold back?
I have been pondering this for somewhile now
I would have thought going through a pinch point in a cycle lane on the left would encourage some drivers to try a squeeze through.
The question for me is more why do they have the cycle lane between pinch points. It encourages cyclists to stay in the gutter and out of the "car lane" which makes it that much more difficult to move into primary position for the pinch point because you are effectively pulling out into "their" lane. Its a bit like the feeder lanes to ASL which are designed to lead you down the inside of lorries waiting at the lights which is absolutely the worst thing you can do.
But then I remember that cycle facilities are not there for cyclists but for drivers and box ticking politicians.
The cycle lane would have to run through the centre of the pinch point so the cyclist would hold primary.
I think* this was kind of my point it would make primary legitimate, as opposed to what the hell is that cyclist doing slowing me down. I think as cyclists primary is a well known riding tactic, but I would hestiate a guess that most mororists assume it is arrogance and that we should be clipping the kerb to allow them to make good progress.
See my post above![]()
But have you ever seen that in practice? The best I've seen is a crap filled cyclist bypass lane to the pinch point.
I have seen some that run in the gutter then other side of the pinch point concrete. So much fun for the cyclist trying to get back into the traffic flow after emerging from that![]()
Surely if the cyclelane runs to the left of the pinchpoint bollard (as some do around here too), then the cycle lane can be easily rejoined after.... if you were in normal traffic flow before the pinch point then you would easily move to primary while going through the pinch point.
Such as here
