Daninplymouth
Hi, il start off by saying I’m not sure if this should be here or in the bike advice forum see please move if appropriate.
I’m just trying to get my head around how bike geometry effects the feel of the bike, so if anyone has any input on the examples below I’d appreciate any feedback.
My simple mind tells me that if your seat height and bar height is roughly the same then do different frame shapes and angles have any impact?
My issue is I ride a 60cm Caad13 which I feel is a bit big so looking into something a little smaller and more endurance based. As my rides are now a lot longer than I planned I would do, but with the current situation test rides seem bit of a no go.
image below shows my caad (light green) overlaid against The 58cm synapse (dark green) and ribble endurance (red)
Here is the caad vs synapse
And caad vs ribble
what I struggle with a bit is the ribble they call an endurance but has a much lower stack than my current frame, but would the slightly higher seat angle position you up closer to the bars?
Also the smaller synapse has a stack very similar to my bike although the frame is more compact and it has a slightly less reach to the bars.
I have put a smaller stem on my caad which has helped a lot but I do still get an occasional pain in my neck, not sure if it is all attributed to cycling or no. But seeing as I’m looking for a new bike I’d like something a bit more comfortable, do you think either of the frames above would offer an improvement on this?
Thanks
And caad vs ribble
Thanks
