Dash cams on EV’s.
Milzy
Usually my dash cams will record movements whilst parked when triggered.
Now I have an EV do I hard wire up as normal or should I have a power bank thing installed along side the dash cam?
Although my I/C battery never drained does the EV 12v not charge back up when moving the same?
C R
Worcester
The 12V battery should recharge the same as in an ICE vehicle.
Drago
We're on our 4th EV, and on all I've simply plugged them straight into the USB C accessory socket. On all of them the socket turns off when the car goes to sleep, which in the volvo takes about 30 seconds, ths Mini about 5 minutes, ths BYD and the MG in between.
DRM
West Yorks
My understanding is that an EV will charge the 12v battery from the traction battery via a DC/DC converter, that drops the typically circa 400v down to 13.8v to charge the 12v battery, it should constantly keep the 12v battery topped using clever electronic monitoring, charging as required
